Dual Zone Technician in Notcross - Atlanta GA area
BenJoseph
BenJoseph Member Posts: 1
Hi
We've dual zone system in one to Townhome property and having trouble regulating Heat in dual zone. If you have recommendation for any Dual Zone experienced technician in the area then would greatly appreciate that. Have tried multiple folks changed Thermostat, Dual Zone Card etc.. but issue doesn't get resolved.
Looking forward to the response & help.
    EBEBRATT-Ed Member Posts: 19,464
    Don't know exactly what you mean by dual zone. I assume this is hot water or warm air heat, or is it a het pump system Pictures will help.
    Maybe you could contact the MFG. or sales rep of the equipment mfg and they could steer you in the right direction for a technician
  • Jellis
    Jellis Member Posts: 232
    when asking a company for a technician to work on your heating system you will need to know
    what kind of heating system do you have? Boiler, furnace, mini splits?
    what fuel? Oil, propane, Natural gas, electric
    roughly what is the problem? 1 zone is not reaching its set temp? both zones not reaching temp?
    Asking for a "dual zone technician" will certainly raise some questions.
    Hope this is helpful.
