Beckett Genisys 7505 constantly recycling.
Colderthanyourex
Member Posts: 1
in Oil Heating
Hello all, I'm a complete novice and brand new homeowner so you may have to spell some things out for me.
I have a Beckett Genisys 7505b oil burner that is getting flame, flashes in "recycle" mode and repeats 3-4 times before going back into lockout. It does not keep a flame nor turn on the blower.
This began after running out of oil. I filled the tank, bled the line and primed the furnace no different than any other day.
you run out of oil regularly?
how old is your tank? clean inside?
you need to change your filter, pump screen, and nozzle, blow the line back to the tank, clean and check the gun and throat, then with your analyzer equipment you need to readjust your burner for proper combustion, draft, and do your smoke test, cleaning the cad cell should keep it running, call a pro.
known to beat dead horses2 -
This. Where are you located?neilc said:.... call a pro.
Consulting0
