Wet Steam
HeatingHelp
Administrator Posts: 707
Wet Steam
Dry steam is the good stuff. “Wet” steam is steam that contains more than 2% water. It’s the bad stuff because the water uses up a good portion of the steam’s latent heat before it can get out into the piping. When that happens, the building suffers. The steam dies in the header and the near-boiler piping. The people freeze.
Thanks Paul, nice0
I'd love to see the rest of the piping on that boiler, because what we can see certainly doesn't look proper. As for insulation, I saw one little bit, but where's the rest?0
Looks like a job for a Trap Header! You can't make dryer steam in these new smaller design boilers. Otherwise, a very cool demonstration of what's going on inside the piping. Noticed a lot of bouncing on the steam gauge. Water condition looked like it had a lot of impurities in it.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
