The Second Most-Common Mistake Made by Geothermal Designers
HeatingHelp
What is a Slinky pit? I ask because i'm wondering if I can install a horizontal ground loop around and under a septic tank and field that would heat or nearly heat a 3000 sq ft house in Quebec. A slinky pit sounds like the inside of a septic tank.0
seems like having a good survey of the type of soil and any ledge or rock would be the first thing to check into. Test boring I guess. yeah, I'd like to know what a slinky pit is as well0
Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
I’m a soso geo fan. Our electric rates are about $0.22 per kWh here in Massachusetts. If you have natural gas, fugetaboutit. I have a system at my home and my office/shop. That compressor simply gobbles juice. I’ve done math with total watts and temp rise and cfm (variable speed/ trustworthy cfm numbers). I run my wall hung nat gas system in winter.
One big concern, many geo installers don’t install enough loop. Antifreeze and back up heat galore
Slinky—- not super ideal unless you want to get the job done quickly and you have a bigger pump to install.
Gary0 -
Slinky’s often pull too much heat out of too little ground and end up with low pressure faults are poor end of season performance.
It’s not just how much pipe you have in the ground, it’s how much much ground you have around the pipe. They have their place but the loads and geology of the ground have to be considered.
I disagree about the same energy on different loops with the same flow and temperature. Required pump power can vary significantly with different loop designs and is often overlooked and can add up significantly over the course of a heating season.0
- 87.8K THE MAIN WALL
- 131 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
