Old NRC Boiler
Dan Foley
Dan Foley Member Posts: 1,268
I saw this one yesterday in the Cathedral Heights section of DC. It still running but we will be replacing it soon. It appears to be a vapor system with graduated inlet valves but there are traps on the radiator outlets.
  • Dan Foley
    A few more pics. The valve has a “B” stamped on it. Barnes & Jones?
  • Fred
    Fred Member Posts: 8,542
    edited January 2019
    Interesting that the boiler plate indicates the boiler has about 33% more Sq. Ft. of steam output with gas or oil compared to Hand Fired (coal, I'm assuming). Certainly better explains why these old boilers are considered way over-sized. Open windows wasn't the issue, conversion was and that was understood even back then. They likely weren't over sized until converted.
    Dan Foley
  • Dan Foley
    Any idea how old this is? My guess is 1940’s
  • Fred
    edited January 2019
    @Dan Foley
    The National Radiator company developed from the earlier Fowler Radiator Company (est. 1894.[1]) which was acquired in 1896 by John and Samuel Waters;[2] after the acquisition the radiator factory was moved from Norristown to Johnstown. In 1902 the company was renamed National Radiator Company.[1]
    The company expanded, and by the 1920s had plants in Trenton, New Jersey, Lebanon, Pennsylvania, and New Castle, Pennsylvania. On 8 Aug 1927 the National Radiator Corporation of Delaware was established with a capital of $25 million; the new group incorporated the Union Radiator Company, the Gurney Heater Manufacturing company, the Continental Heater Company, the Niagra Radiator and Boiler Company, and the Utica Heating Company.[2][3] In 1929 the company established an industrial research laboratory.[4]
    In the early 1930s the company required reorganisation due to debt problems, and was placed into receivership and subsequently re-established.[5][6][7][8]
    In 1951 a fire at the company's "Century" plant (Moxham) killed one person, and caused $1 million of damage.[9]
    In 1954 the directors of the company approved a merger with the United States Radiator Corporation.
    Could be even older than the 1940's. There is a Patent # on that boiler plate. Wonder when it was filed?
  • Dan Foley
    Thx, Fred. Maybe early 50’s?
    Either way it is time for an upgrade.
  • Fred
    @Dan Foley , I couldn't find that patent but I found several around it and they are all dated 1941 so it is safe to assume that boiler is somewhere after 1941 (since it is not a "Patent Pending") and 1954 when they merged with US Radiator.
    Steamhead Member Posts: 18,470
    Ohio Brass. The circle around the B is the O. Barnes & Jones used a B&J logo. What make are the traps?
    I'd say early 1950s on that boiler. They were built like tanks and would last a long time. We still run into them around Baltimore and have upgraded a few with baffles and flame-retention burners when the owners aren't ready to replace them. See this thread:
    https://forum.heatinghelp.com/discussion/160431/any-hope-for-my-national-heat-extractor-100-series-oil-boiler
    Be aware these had asbestos insulation under the jackets, which will require abatement.
    If possible, I wouldn't mind getting a hold of that InterBurner and Vaporstat. That was one of the first flame-retention burners and I've never actually seen one. Besides, it would be good to see you again- it's been a while.
    Consulting
    HVACNUT Member Posts: 7,426
    What about the oil guys?
    Any good burner pics?
    I can make out a burner design logo but cant read the name. That thing looks awesome.
    I think that's the first I've seen without the snail shell housing. Looks like a first gen R8184G too, but that would've come much later than the burner or boiler.
    I collect older oil burner logo plates so if you wind up replacing, I'll pay shipping.
