Is Alpha2 a direct replacement for 15-58?
sunlight33
Just want to know if the flanges on 15-58 are also compatible with Alpha2. They are Webstone Flanged Ball Valve w/ Drain.
Yes0
@sunlight33 those Webstone iso flanges usually fit most 2-hole pump flanges. The flange to flange spacing might be different with the different pump, but the flange bolt holes should line up just fine."Don't try to win an argument; instead, try to have a conversation." -Steve Deace0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
