Guess the schmoo
gmcinnes
gmcinnes Member Posts: 120
Hi guys. My new boiler has been in operation for about a month now.
Because there were concerns about low return temps, and because I just can't leave well enough alone, I popped open the firebox and had a look. I discovered two piles of white powder. In both cases it appears at what looks like a seam in the firebox. It's sort of flaky, but also relatively well consolidated - i.e. it takes a good poke with a screwdriver to loosen a flake.
Any ideas what it is?
  • STEVEusaPA
    Looks like insulation off of the boiler door. In your first pic, if the entire door were a clock, look at the spot between 9 & 10.
    I'd vacuum it out, check again in a few months, compare pictures.
    EBEBRATT-Ed Member Posts: 17,546
    Low return temperature. What is your return temp? Refractory insulation stain looks like flue gas condensation combined with soot
  • STEVEusaPA
    Ed, do you think any refractory is missing where I mentioned (lower left side of upper left quadrant)? I'd suspect seeing more white crusties if it was condensing, not in just that one spot.
  • gmcinnes
    @STEVEusaPA I don't think there's any refractory missing.
    Although the picture does give that impression, it doesn't look like it in person.
    @EBEBRATT-Ed It's a cold start boiler on a high mass system, with an outdoor reset. So, the return temps can be as low as 70F on the first gulp of a zone that's been off for a while. They usually get up to about 130F by 10 minutes. There's a long thread discussing the low return temps and the boiler bypass piping here.
    The TL;DR of that is that the delta T through the boiler is about 35F-40F and the flue gas temp is about 305F after about 10 minutes run time. Not stellar, but what do you think?
