what outdoor sensor do i need for IBC modcon boiler?
fiddlermd
Member Posts: 59
in Gas Heating
I know that there are several out there and they all look more or less the same (same OEM?)
just want to know which sensor will work and whether I need to change any settings to get it to do its thing.
thanks!
thanks!
You can download the book for your boiler from IBC here:
ibcboiler.com/support/TIPortal/Content/Guides%20and%20manuals/SL_20-115_G2_Installation.pdf
At the bottom of page 1-29 it says:NOTE: Sensors connected to any sensor input contacts must be of NTC Thermister - type with a resistance of 10,000 ohms at 25°C and β = 3892. We do not recommend using 3rd party supplied sensors. Compatible water temperature sensors and outdoor sensors can be supplied by your IBC distributor.0 -
There should have been one supplied w/ your boiler....0
Yes what kcopp said.0
- 15.8K Strictly Steam
