oil line protection
kcopp
Member Posts: 4,663
in Oil Heating
Anyone know what the metal channel is called that you can get to protect an oil line that runs above the floor.?
I was looking for a triangular shaped cap that goes on AFTER the oil line was placed on the floor.
I wanted to bump this thread to see if anyone else has any help for @kcopp.
I’m interested in this product also.
For short distances I’ve used a commercial door threshold, but what you are looking for sounds much better-maybe similar to mini split line set covers that go up the wall.
How about something like this:
https://www.cableorganizer.com/cord-cover-duraline/There was an error rendering this rich post.
How about angle iron, or a short height steel C or U channel section?
Bolt it down, it won't go anywhere.
https://www.bing.com/images/search?q=steel+channel+section&FORM=HDRSC2
https://www.bing.com/images/search?view=detailV2&id=4C83FDFB91717256D0043373EA70B886619222C1&thid=OIP.OSG3GH0akDDDlw6kcV0BrQHaE0&mediaurl=https://is.alicdn.com/img/pb/052/241/200/1200241052_916.jpg&exph=390&expw=600&q=steel+channel+section&selectedindex=41&ajaxhist=0&vt=0&eim=1,2,60 -
I have seen this product before but there is no name or ID on it.0
