Flue collector removal
newhouse34
Member Posts: 9
Trying to remove flue collector to access baffles and I’m at a standstill with single digit temps in ny.. Utica boiler usc4lp.. I removed two side bolts holding it to boiler castings and removed caulk from back and the sides. The box will start lifting up from the back but it seems to be anchored some how on the front so it won’t come off. I’m afraid to force it and break something since it’s my first time with this boiler.. is there something I’m missing or a trick to getting it off ?
It says in the manual to do this annually to clean the baffles0
- 120 Geothermal
