Steam Boiler radiator problem
Pegret
Pegret Member Posts: 37
edited January 2019 in THE MAIN WALL
Had a new Weil-McClain steam boiler installed in my 1928 house. It's been a huge struggle. Voilent banging pipes and water gushing all over floor. Plumber tried many things and finally repiped correctly (according to manual) and it's now working fine except...one radiator comes on only if I turn the thermostat up 3 or more degrees at once. Even then it's the last one to come on and sometimes only warms 3 or 4 columns. But sometimes it heats completely. When maintaining the same temp., it never works at all. Of course most of the time I keep it at one temp so this means most of the time it's cold! There's no problem with the radiator itself- plumber confirmed today that the radiator and vent are fine.
The radiator is located in an addition on the first floor, surrounded by windows and is my favorite room. Today plumber turned vents to 1/2 positions on other radiators on first floor thinking the thermostat reads warmth from them before this rad has a chance to come on. Interesting theory but, once again, when I kept temp set and a new cycle came on, the rad didn't come on. I've been on the phone with Weil-Mclain technical services several times and they can't figure this out, either.
  • JohnNY
    JohnNY Member Posts: 3,371
    So, 3 posts about this radiator?
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • Pegret
    yes
  • retiredguy
    retiredguy Member Posts: 1,094
    Is this system a 1 or 2 pipe system? Can you post a drawing of the house and the addition and show the size of the supply piping including the piping for the radiator that does not heat? Where are the main line vents located and type/model? Did this system ever work correctly? When they installed the new boiler did they pipe the "near boiler piping" correctly?
  • Pegret
    i think it's one pipe but can't really answer most questions as I don't understand boilers and the system. I plan to take ideas and recommendations given here to my plumber.
