What style and EDR is this radiator?
Matt722
Member Posts: 14
Is this a one column thin tube rad? It has horizontal venting on top and bottom like a tube rad but there is no hollow middle just vertical cast iron. There are 24 sections (looks like 4 rads of 6 sections piped together) its only 3” think. The height from floor is 30” although there are 2” floor brackets on opposite ends holding it up so maybe it’s only 28” tall.
Im doing a renovation in this room soon and it has to be removed. I love the red and hate for it to be damaged. If it were any idea where I could get a replacement?
Thanks!
Thanks!
It's a Rococo Wall Radiator, page 64 of Dan's book, "Every Darn Radiator". looks like the Model 9B. Height= 29-1/16", Section width = 13-3/16", Thickness = 3-1/16" , 9EDR per Section
Don't let it be damaged and it won't have to be replaced!!!0 -
Why does it need to be replaced? Can you remove it, renovate, and then re-install?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
thanks Fred. exactly what i was looking for. Brewbeer, that is the plan but its good to know just in case it does get damaged0
@Nysteamer Count it as 4 sections 4X9 = 36 EDR Total0
- 50 Industry Classes
