Adding a Skim Port
The skim port knockout on my Burnham V8 was never removed.
Can I install a T fitting on the Pressuretrol port and use that as a skim port?
Ill put a cap on the nipple when not in use.
  • adasilva
    adasilva Member Posts: 144
    Sure can, that's how I have mine set up and it does the trick!
