Triangle Tube CC50s diagnostics
Voyager
Member Posts: 403
in Gas Heating
Is there a way to see the current firing rate of a CC50s boiler? I am curious to know at what level of turn-down mine is at during different run times, but I have found no information in the I&M manual in this regard.
Not that I am aware of.... The control is not that sophisticated.
The IBC HC13-50 has a similar control board and that has some advanced settings you can look at.
