"Flushing/Descaling" a Bosch Greenstar Combi 151 boiler (zwb 42-3)
GeorgeLI
GeorgeLI Member Posts: 3
Hi All,
My original installer sent two different techs to my home and offered an "annual routine flush/descale" of our boiler system for a lot of money. The problem is I got two different stories from the two techs that came out (at different times)
One tech said they only flush the water supply lines (circled in yellow, #1 & #5 in the diagram), but another tech said they also flush the heat supply lines (circled in red, #2 & #4 in the diagram).
Any input would be greatly appreciated. I do not want to spend many hundreds and have only half the job done, or worse, have the wrong lines flushed.
NOTE: this unit provides both hot water AND heat to the home. I think most systems have only hot water, and therefore only need that flushed. Mine has two systems, hence my question.
Thank you!
  • Leon82
    Leon82 Member Posts: 684
    Usually it just the domestic hot water that is flushed. Unless the heating side got plugged, but that would raise concern about a problem with the system
  • GeorgeLI
    No, heating side is fine, their service is for just routine flushing. So thank you SO MUCH for the input Leon!
    Any other opinions?
  • SuperJ
    SuperJ Member Posts: 609
    edited December 2018
    You're better off to insist on documented water quality (TotalDissolvedSolids/conductivity, PH, etc.) and documented combustion analysis/adjustment than flushing and refilling the heating water side of the boiler. Adding new water to a system filled with good water something to avoid.
    The DHW side needs routine maintenance to avoid scaling up with minerals.
    The burner could be cleaned though.
  • GeorgeLI
    OK, great. Then only a flush of the DHW then (for routine maintenance)
    Thanks for all your input Guys!
  • DZoro
    DZoro Member Posts: 1,048
    I would assume they cleaned the burner side of the system?? Flue analysis, and left the results with the boiler :)
    D
    hot_rod Member Posts: 27,339
    The owners manual does give you guidelines for service interval and procedure. The warranty may be dependent on services being performed and documented
