Thermodynamics CWL85LE
verticaldown
Member Posts: 3
in Oil Heating
Has any one purchased part# 337805(Cerablanket floor insulation) or part# 337800(Ceraform floor board 19x19) for a thermodynamics CWL85LE oil fired boiler
No, I usually replace the boiler to a 3 pass or an EK.0
That's not a bad boiler. Why do you need to replace the blanket?
My guess would be you are the first person to pull the burner on a cleaning and it's a mess in there.
Getting the front off to replace it could be a daunting task.
The best thing about vertical baffle boilers is that they are easy to clean, no pins.
The biggest problem with vertical baffle boilers is when the baffles break they usually fall into the chamber, but the broken piece is just long enough to stay vertical in front of the flame and create havoc. These baffles are pretty short so not as bad as a Columbia Emerald.There was an error rendering this rich post.
seeing if it has been done, seems like a little hole to install that 19 x 19 board. seems intact, boiler is installed in a levittown,pa "rancher" home. which is in the bathroom. little access in front of boiler. Have you ever purchased these items or replaced with other options. thanks for your response0
You should be able to pull the burner and look inside. Which should be done on every cleaning. But you may do more harm than good, as you could break a bolt or 3. First you'll need a new burner flange gasket. Or you can remove the entire front, in which case you may damage the door panel and of course break some bolts.
Then you may need a new rope gasket. But if I recall, on that boiler the door panel may also be the gasket.
Besides what appears to be general curiosity, are you having an actual problem?There was an error rendering this rich post.
no door on this model unless they hide it real good behind the jacket. no problem, kid just bought house, did a cleaning, just seeing if available, and if anyone had a exploded view of boiler , did notice burner flange was rotted at bottom, apparently a water leak, but no sign of leak at cleaning .0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
