Help With switch on date
Cpthowdy758
Member Posts: 1
My father recently moved in to a house with in-floor heating that's powered by a Wirsbo ProMix 212. The previous owner has it set to switch on in December. My father needs it on now. How do I bypass this?
A lot of those like this brand and others are actually Tekmar controls.
this manual covers the programming
https://www.uponorpro.com/~/media/extranet/files/archived docs/promix 212 installation manual.ashx?version=062620181039
As far as I remember or see in the manual there is no program for dates, dates on or off, they probably either have it in Idle mode or the WWSD ( warm weather shut down) has it disabled, don't change any other parameters, these controls are somewhat complicated so if you alter things you could open a can of worms. If the display is blank power to it is off, somewhere, you'll have to follow the wires from it.
