Is it time to wave the white flag on my gas-adapted steam-heat boiler?
Niall
Member Posts: 3
Hi everyone,
my house is a fairly typical 1931 house on Long Island, NY. The heating space is approx 3,000 sq ft. We converted from oil to gas with an Economite Model E20B gun on a Burnham V85 boiler shortly after moving in 13 years ago. The heating has never been balanced or consistent and certain radiators never radiated much heat at all. Many HVAC folk have tried their hand at solving that puzzle and failed.
Now, turning on the system over the past few days has triggered my gas alarm so at minimum I need some repair for that (I have turned the system off and shut off the gas supply). I'm thinking it might be time to replace the boiler for a dedicated gas boiler. Is this a prudent next step and would it increase the chances of more consistent heat distribution? If so, would love to hear recommendations (perhaps Burnham SIN3LNILE2 ?) and approx cost of going that route.
Thanks in advance from a newbie.
Boiler
Piping, with vent. Line to the right going into ceiling supplies a radiator (pictured below) above it. Line to the left supplies a seperate radiator.
This is in the basement.
Radiator on first floor supplied by above.0 -
The Midco E20 is the wrong burner for that boiler. It can't move enough air through the flue passages. I'd upgrade to a Carlin EZ-Gas, with which it would work much better.All Steamed Up, Inc.
Consulting2 -
Steamhead, what other boilers would the Midco e20 work with, instead of the Burnham he has, (that information might make the Midco easier to sell if he replaces it).—NBC0
Where in Long Island are you located @Niall?0
@Danny Scully I sent you my location directly. Thanks.
@Steamhead Thanks. Until yesterday had my doubts that any conversion was efficient enough but this forum has put that doubt to rest (a bit!).
@nicholas bonham-carter BTW the vent has been replaced at least twice also. The radiator vents have all been changed in the past.
@Jim_R thanks for the etiquette advice. Apologies for mentioning $ here. As for previous attempts at fixing this, some of the stories are comical but are similar to yours!0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
- 19 Recall Announcements
