Piping question
aldefed
aldefed Member Posts: 32
Hello,
Currently, my secondary circulator pump feeds four branches that go to my radiant manifolds. I want to break this into 2 zones with zone valves (2 branches on each zone valve). What is the best way to "Tee" the outlet of the circulator pump into the 2 zone valves? The circulator pump is oriented vertically and I would like the zone valves to be vertical directly above the pump. Pumping into the bull of the Tee would be easy but I didn't think it was proper to do that.
Thanks,
Al
