Love these old pics...
Timco
Member Posts: 3,040
Overalls, ties and suspenders. The good old days0
I'd say the guy on the left is the journeyman (hat means journeyman), the middle guy is the salesman (tie) and they guy on the right is the apprentice (ears).
Thanks for sharing those great photos of those who preceded us.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
When dress code actually gave one status.
Great pictures!
Can anyone read the pressure gauge?
Steam heat with the double hung window thermostat.
Is there snow on the ground outside, the leaves are still on the trees though.
If snow, that radiator could probably melt it with the windows open.0 -
It looks like they're pressure testing the system with hose attached.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
