entry return on a monoflow
BennyT
Member Posts: 2
Can someone confirm that the venturi is on the return, I believe the flow is following the red arrow. The rad is below the main.
Thanks
Thanks
Yes, and the bull of that Tee is the supply for that rad.
Why? You just gonna leave us hanging?0 -
sometimes below the main requires two venturis one on the supply and return0
Thanks,
I have a myson T6 connected and it is imperative that the supply (bullhead tee) is connected on the entry side of the rad.
I had the boiler changed last year and the rad stopped heating. I am quite sure it was working ok before (maybe not as well as if it had two monoflow tees in opposite direction). I was scared it was connected the wrong way, but I might have an air problem it seems.
Could the venturi in the picture be used as an entry, if I had an identical venturi downstream to use as a return? They are not in opposite direction, is this type even reversible?0
