How often to flush radiant loops ?
moots
Member Posts: 37
Hi Folks:
I have a Burnham boiler with a combination of copper and mostly older galvanized ? piping for water based heat. Every few years in the past I have flushed the lines out which resulted in quite a bit of brown/dark water per zone I assume from aging piping and aging baseboard radiators.
How often or should I even do this for maintenance ?
Maybe every 3 years ?
thanks,
Dave
thanks,
Dave
Do not flush routinely. Every time you flush, you wind up injecting air that is entrained or dissolved in the fresh water, which causes corrosion. The brown water is normal and harmless - it quickly returns after flushing.
Hydronic systems normally use black steel pipe, not galvanized. If yours is galvanized, that is fine though.2 -
As little as possible. Put in good water with some hydronic conditioner and leave it be.
Every time you add new water you are adding more O2 and minerals to the system and making conditions worse.
The water will always have some color to it when you open a drain, that is not a problem.
If you have some of the early radiant tube like Heatway Entran 2, or grey polybutylene, you need to keep a chemical regiment as those tubes allow O2 into the system. And/ or use all non ferrous components in non barrier tube systems.
Now a water heater is a different animal, flush those occasionally to help keep the sediment out.Bob "hot rod" Rohr
Living the hydronic dream0
- 120 Geothermal
