C-Wire for new T-stat
Steve Garson_2
Member Posts: 712
I have a new (old) home with the old Honeywell round t-stats. I would like to install a set-back t-stat that requires a c-wire. Looking at the zone valves in the basement, I can see that only two wires are used. The green wire is not connected. Obviously, the same is the case at the t-stat location.
When do I connect the green wire to provide the c-wire at the new thermostat? The boiler is a WM GV-5.
Thanks,
Steve
Denver, CO (previously Boston)
Thanks,
Steve
Steve from Denver, CO
Hi Steve:
Many set-back thermostats don't need a c-wire, but it sounds as though yours does. Double check.
You could possibly find a c-wire on your boiler, but I would stay away from that option since you could accidentally short out the transformer which may mean having to replace the boiler's circuit board.
The best option is to install a zone valve controller that has a c-wire connection available as does Caleffi or Taco. Caleffi is shown here:
https://s3.amazonaws.com/s3.supplyhouse.com/product_files/ZVR103-submittal.pdf
You will have to re-wire your zone valves and your boiler end switch. Easy if you've done it before; a weekend project if you haven't.
I think I'll simply buy a different T-stat. Thanks for your response. SteveSteve from Denver, CO0
I powered my Emerson Sensi with an external wall wart for my "no c wire" application
https://sensi.emerson.com/en-us/support/adding-a-24-vac-external-transformer
https://www.homedepot.com/p/Emerson-Sensi-Wi-Fi-Thermostat-for-Smart-Home-ST55/301231478
TimWinter Park, CO & Arvada, CO0
- 50 Industry Classes
