Solution boilers
Ductman69
Member Posts: 1
in Gas Heating
Solution boilers I live in Michigan and I was wondering what I should have my differential and my high fire set at
Depends on the system you have. Can you give us a little more information? what kind of heat emmitters, how is it piped, what other controls do you have, does the boiler also do DHW? do you have the outdoor sensor hooked up?0
