Leak near valve, what's the fix?
bipbap
Member Posts: 233
I noticed a slight drip near one of our steam radiator valves. It's not at the valve but close. It's at the dark line in photo.
What's the fix for it?
I've also noticed this radiator sounds like it's a pot of boiling water when the heat kicks on and the vent spits and sputters water.
Is there maybe water sitting in it and it caused this pipe to rust or leak?
Any ideas?
Thank you!
Any ideas?
Thank you!
That is from the bonnet of the valve, which can be unscrewed, and thoroughly cleaned before bing put back on with just a smidgon of some hightemperature automotive caulk, (others here may have specific brand names).
I do notice some string dropping out of the packing nut which should not be there, but if it isn’t leaking, you can leave it in place.—NBC0 -
Time to replace the valve.New England SteamWorks
newenglandsteamworks.com0 -
Good eye @Fred , I thought that was a cobweb at first but I suspect you are correct.0
I think the packing nut is not cracked but has a piece of hair or something on it. But overall probably better off replacing the valve.0
Hey guys, I also have a leak from the same place on one of our valves… I took off the bonnet and there seems to be some sort of crumbly old gasket there... I thought the bonnet was supposed to be a metal on metal seal? Any advice on whether I should use some sort of gasket or sealant or just put it back after a thorough cleaning? Would appreciate your insights.0
I have used Teflon rope packing, very small diameter.
Roll a little around the shaft and tighten the bonnet. Add more and retighten. It will conform to the shape needed.
Just don't try too much at a time as the bonnet may crack or strip.
Also there is some high temp plumber grease for the shaft threads if you need it.
If you were at a dead man's auction 30 years ago you might have picked up a roll of "Lucky Strike" asbestos packing, probably has some lead in it for lubricity. But those ships have sailed.0 -
If you are talking about the bonnet, as opposed to the packing nut, then some valves had a hard gasket, and some had a metal to metal seal.
Clean the surfaces thoroughly, examine them for dents, gouges, etc, and try it metal to metal. If that doesn’t work, some silicone gasket goo would probably fix it, as it should only have to hold a couple of ounces of pressure.—NBC0 -
I would first try to fix the valve and the floor
Located in durham NC.
