Parts for a 12 year old Munchkin 140M needed. (911)
Tim@HeatingAndCoolingFixations
Member Posts: 4
Looking for a used mod. 140M. that could be parted out. I have a customer that inadvertently through away some parts off his 140 M Munchkin boiler. I need everything from the gas valve down to and including the burner door. He thought they were old, used no longer needed parts and tossed them in the trash. I had it apart so I could clean the heat exchanger the next day. Any help would be greatly appreciated.
Why do you have two posts for the same request? Best bet would be H.T.P. or possibly check on line.0
