Capping unused steam pipe in 1 pipe steam sysytem
Just finished a big renovation, part of that was taking down some walls on our first floor. There was an old steam pipe which lead to the upstairs bathroom. The upstairs bathroom however does not have steam heat radiator (was removed by previous owner) the pipe never got hot, so assumed it was dead. it was removed, and the work finished. yesterday needed to turn the heat on for the first time, and went to check the boiler to find steam shooting through the old pipe, it had not been capped. Plumber came, cut the line and capped it. My question is, why would steam still be shooting through this pipe, weird since it never got hot, and then is capping it ok to do?
If it was capped before and had no vent it won't get hot. Where there is air there can not be steam. This would be considered normal behavior IMHO.
Also your contractor not realizing this makes me suspect his knowledge base with respect to steam.
The capping should be fine.0 -
KC-That makes a lot of sense, yes, thank you for the response.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
