29 Gal 60K water heater
Tim Potter
Member Posts: 274
Does anyone have any experience with the Rheem / Rudd / Richmond 29 gal Induced draft 60,000 btu Nat Gas water heaters?
https://cdn.globalimageserver.com/FetchDocument.aspx?ID=33A02F15-A60E-4D58-B2BC-5F3A4F08F43E
Claims to outperform a std 50 gal by 34% with a 61gph recovery @ 90* rise
Daughter has a 50 gal from 2001 in house she just purchased, It's atmospheric, & Its not convenient to run PVC for High efficiency WH.
Thanks,
Tim
Thanks,
Tim
Winter Park, CO & Arvada, CO
For typical residential situations, the cost of natural gas fuel for even a garden-variety, atmospheric water heater is peanuts, unless you have a houseful of teenagers. I don't think you could economically justify replacing a heater that works with a more efficient unit. The payback period would be too long.0
If venting is an issue a Hybrid electric may be a good option.
https://www.statewaterheaters.com/products/residential/electric/proline/xe/heat-pump/0 -
Thanks, a new water is going in, the one thats there is the original to the house, & coming up on 20 years. The decision is: std 50 gal with 40k burner or 29 gal with 60k burner that claims to outperform the 50/40 combo. both have minor rebates from Xcel energy. not much difference in price either way.Winter Park, CO & Arvada, CO0
You cant power vent that into a standard chimney. Must go to the outside. Is the present chimney lined?0
Thanks KC, no brick chimney, its a 2000 era double wall b vent used to vent a 80% furnace & water heater. I thought it was a drop in for a 50 atmospheric according to this:
http://cdn.globalimageserver.com/FetchDocument.aspx?ID=8a10538c-ca79-452c-83d4-1ce565e25f9f
Did I read it wrong?
TimWinter Park, CO & Arvada, CO0
