TRT unit heater
Does anyone have any info on TRT unit heaters? I'm looking for capacity etc. A Google search comes up empty. I'm guessing this is less than 20 years old.
Model# 98ER16-T12
Serial# 8269-92
Thank you!
    hot_rod Member Posts: 26,638
    just a bunch of legal stuff when you search that name. Measure the coil and maybe compared to a Modine or other brand.
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    Yeah that's what I found too.
    Coil is 18x18 by 4" thick parallel flow.
  • GroundUp
    GroundUp Member Posts: 2,467
    The 18x18x3.5 I use are rated at 130k at 13.5 GPM and 1500 CFM, 180* EWT
    Solid_Fuel_Man
