Manifold
Member Posts: 4,704
I'm looking for a manifold that has Uponor outlets. I just need a return manifold.
This one by Sioux Chief has crimp outlets.
https://s3.amazonaws.com/s3.supplyhouse.com/images/products/large/672xv0442-3.jpg
Do you want the valves on it?
Watts Radiant and Alberta T-drill still build a wide selection.
And Dahl has a lot of mini ball valve configurations,
Maybe just get a copper stub manifold and solder on the 1960 adapter?Bob "hot rod" Rohr
Thanks, hr. I found one made by Roth that will work.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 50 Industry Classes
