Friedrich OLA 095 AMA Warm Air furnace
RayH
Member Posts: 101
in Oil Heating
Friedrich is now into Heat Pumps & Air conditioning. I'm trying to find info about this residential warm air furnace? Can't find anything on the web.
Does anyone know how to find info on dinosaurs ?
I'm sure it's pretty old. What is it you need to know? Is it that old that it has a stack primary relay? What's the model and serial numbers? What make and model burner? Is the wiring diagram iside the jacket cover? Everything should be typical of the age.0
I have Model OLA 095 AMA Serial #P564655. Unable to find anything based on this information. I'm guessing 1960's0
Can you post some pics. I'm sure it's no different than most furnaces of the time. Burner, fan/limit and blower motor.0
It's probably toast0
Friedrich has been around for a long time. They sold their residential product line to ARCO around 1980, then SnyderGeneral bought it, then ICP.0
- 120 Geothermal
