20' pex lengths for heating
GW
Member Posts: 4,695
Does Viega still make 20' lengths for heating? Looking for 1/2" The local vendor says they don't have
yes Viega still has 1/2” x 20’ lengths of radiant pex.
They also have 1/2” x 20’ lengths of their Fostapex with aluminum barrier that can be used on boiler systems.0 -
What wholesaler are you working with?
I am still getting 20 ft sticks of barrier Viega in 1" from the local supply house. Never checked 1/2" but I would imagine the same rule applies0
Should be Black pex tubing with red stripe0
Yes thanks they do have 1/2 Fosta but not the black and red. Northampton plumbing supply doesn’t have it.. I’ll check with Webb, thanks0
same with webb, they have the 3/4 but not the 1/2. Not a biggie, I was just looking for some regular straight 1/2"0
Looks like Viega only makes 1/2” fostapex in 20’ lengths.
The black radiant pex starts at 3/4” x 20’ lengths.
Sorry.0 -
Thanks Bob we just used to Hydonic Alternatives tubing0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
