gas mod/con sizing - please help!
fiddlermd
fiddlermd Member Posts: 59
I posted this on the main wall before realizing there's a separate forum.. so moderators, if need be, remove the offending post.
Hello everyone, I'm very new to this whole thing so forgive my ignorance.
I recently bought a home in northern NJ and am renovating. part of the renovation is getting rid of old boiler and replacing with something a lot more efficient without a chimney.
So far I got far enough to know that i'd like a mod/con boiler with an indirect water heater tank.
Now i'm researching brands/types/etc.. and came to various discussions of how a mod/con can and should be sized properly... and that following generic calculators can lead to efficiency loss.. so with that said.. here are the specs:
the house is about 3700 sf. Built in 1972.
There will be a total of 7 heating zones. 2 of them will be radiant, the rest will be baseboards. radiant will be in the kitchen ( about 400 sf) and master bath.
House has 5 bedrooms (4 upstairs, 1 down) and 3 total baths
Insulation in most of the house will be new and older parts seem fairly well insulated.
What else do I need to explain to get some idea of how to size it properly?
Thank you all!
  • Snowmelt
    Snowmelt Member Posts: 1,457
    my two personal choices to go with are Utica or Navian - both I would you a indirect water heater.
    to size it correctly you will need to do a heat loss calculation.
    that details getting all of your r-value of windows, doors and insulation in the walls, do some multiplying calculations and come up with a BTU number. there are programs for that, I use taco from flow pro or do it with a book ( heatloss H-22) manually. but after you get a heat loss of house, you still have to set up proper pumps , air elimination. if you want give me a private message with phone number and I can give you a better idea of what you need. ( I am in Linden NJ)
