Understanding the L8124E Triple aquastat relay
Joseph_4
Member Posts: 319
Hi I'm trying to get a customer Hot water. His Boiler isnt firing and I see no power is going to B1 and B2
Im used to the L8148E that when u power the control u have 24 volts on t and tv immediatley and when i put jumper on t and tv relay closes boiler fires and circulator comes on..
I assumed the L8124E works same way and when i got there i see power to control and nothing on T and Tv (or 1.8 volts) so i assumed control bad. I swapped out control and getting same result so now I question if Im understanding control correctly.
Any help would be greatly appreciated.
Thank
Joe
HHI Services
Thank
Joe
HHI Services
If you have 120 volt power to the control and jump T & TV. 1k relay should pulli in and start the circ pump wired to c1 & c2.
The purner should also start (power on B1 & b2 ) if the high limit and low limit inside the control are calling0
