Is this system piped the best way???
brandonf
brandonf Member Posts: 205
edited April 2018 in THE MAIN WALL
https://youtu.be/vUAOvIiFvos
My parents house. One floor bungalow. Original boiler was at least 50 years old. Very square and very green and oil-fired. Wondering if the system is plumbed correctly for the newer boiler which was installed 10 years ago. House has cast iron radiators and cast iron baseboard and one regular baseboard for the new bathroom. They are all tapped off of the loop the same way. Boiler seems to be set at 180 degrees.
Homeowner, Entrepreneur, Mechanic, Electrician,
"The toes you step on today are connected to the butt you'll have to kiss tomorrow". ---Vincent "Buddy" Cianci
  • brandonf
    No takers??
    [Deleted User]
  • unclejohn
    unclejohn Member Posts: 1,833
    Looks ok to me. You have a diverter Tee system
  • Grallert
    Grallert Member Posts: 955
    Nothing jumps out at me. Is it working?
  • SuperTech
    SuperTech Member Posts: 2,569
    It would be better if the circulator was on the supply side, pumping away from the expansion tank. I like the cast iron emmiters.
  • brandonf
    It works. Just seems like the kitchen baseboard should be putting out more heat.
  • the_donut
    the_donut Member Posts: 374
    You could add a balance valve inbetween supply and return. The more closed the valve is, the more flow will prefer to go to baseboard.
  • JUGHNE
    JUGHNE Member Posts: 11,386
    Some of the tees shown had hex wrench bosses with a ring/groove on one end. Other tees looked normal.
    Each emitter should have one of the special diverter tees to or from it. Could one have been removed and a standard tee installed?
    To get more water thru the kitchen BB you have to "pinch" the pipe between the supply and return to divert that flow.
    But size of the BB matters and its location in the room.
    SuperTech
