Concentric Termination extension
McNamara
Member Posts: 1
I just had a new High efficiency gas boiler installed. They used a single pipe for venting fresh air in and exhaust out with a concentric terminator kit. But they also added a "periscope" type pipe to the end of the terminator - to get clear of mounting snow I suppose. I was under the impression a concentric termination was carefully engineered to maximize the exhaust and intake air currents. My question is this - now that the concentric terminator is no longer technically the termination - is it still able to do it's job with two elbow joints and 30 inches of pipe in front of it?
If the installer was worried about the highest snow level, then all the piping termination should have been raised.
I think he was just trying to take an extra precaution against exhaust-intake contamination. Maybe the exhaust extension should point down so as to prevent condensate from building up in the pipe.
Your owner/installation manual will have the final say on that setup.—NBC0 -
How high above snow level is the air inlet cone at the bottom?0
As long as he didn't exceed his piping lengths limits, it should be good.
I'm actually thinking he is more concerned with the re ingestion of exhaust gas.
Is the intake hood above anticipated snow depth?
What kind of system?0
What’s the boiler manufactures manual say, and are there any local codes in your area ? That’s not a concentric0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
