Removing scale..
Timco
Member Posts: 3,040
Customer has a HTP EFTC combi Boiler. The Water report is like 1000-2000ppm dissolved minerals and is very hard. In 18 months of service the 3/4” CSST coil (holds 15 gal in the coil) is down to 1.07 GPM through the coil.
I used 3 gallons of Flow Aid (one gallon then tried two) and it only reacted for 10-15 min then just circulated mostly clear fluid. Just bought 2 gallons of Hercules brand scaler and will try that.
Any other suggestions? Pump it in reverse flow? I’ve installed a Nuvo Manor softener and a good filter in-line but the damage is done.
Thanks. Tim
Thanks. Tim
Just a guy running some pipes.
I think you are on the right path with de-lime chemicals. It may need to run for a few hours to do a thorough job. I suspect that corrugated tube may be harder to de-lime with all the ridges surface?
Keep in mind it is a very thin walled tube, too much acid may pin hole it.Bob "hot rod" Rohr
What about installing a product that Field Controls has called the Clear Wave. www.fieldcontrols.com look under products then under water treatment. This unit is supposed to be a descaler.
Anyone using this product? Does it work?
What about Watts OneFlow units? This unit is also a descaler.
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
