What is the purpose of this vent type fitting, on this one pipe steam system radiator?
Dennis
Member Posts: 124
The fitting is 3/4 inch.
That's not a vent fitting and it serves no purpose on a single pipe steam system. It looks more like a drain plug or maybe just a plug that someone put in it to convert it from a hot water radiator to a steam radiator. That radiator0
That should be a Monitor "Bi-Loop" radiator. It was made to hold a quantity of water, and the incoming steam would heat the water, which would hold its heat longer than cast-iron would by itself. The drain was so you could winterize the radiator so it wouldn't freeze.
Somewhere, I have a diagram of these radiators.All Steamed Up, Inc.
Consulting1 -
So was there a "dam" to retain that water to one side so as to not produce water hammer as steam entered?
I understand the added mass of the water.
If heated to steam temp and then going into a vacuum would that water boil? WAG.0 -
Found it- this is the 2-pipe version, but it works the same way:
@Erin Holohan Haskell , this might be good to add to the Heating Museum under Radiators.
Consulting-1 -
huh. learn something new every day! thanks @Steamhead0
Fantastic! Thanks, @Steamhead. Where'd you track it down?Steamhead said:Found it- this is the 2-pipe version, but it works the same way:
@Erin Holohan Haskell , this might be good to add to the Heating Museum under Radiators.President
HeatingHelp.com0 -
Wow, that is really neat. And something I would have never thought. Thanks for sharing that @SteamheadNever stop learning.0
Seems like a half way between steam and water. Notice the big cutdown on sq ft edr.0
Yes, with the reduction in EDR, I'm not sure it was a very good idea. Kind of self defeating. Guess that's why it is now a rarity.0
1922 ASHVE Guide. That company doesn't appear in later Guides, which makes me think they didn't last long. Perhaps the reduced heat output and/or increased cost had something to do with it. But I've seen these in Baltimore, and as usual, was the only one who had worked on the system to know what they wereErin Holohan Haskell said:Fantastic! Thanks, @Steamhead. Where'd you track it down?
Consulting1 -
Learn something every day, thanks... I wonder if its thought of use was for Appartment buildings ?
Thanks!
President
HeatingHelp.com0 -
Here it is: https://heatinghelp.com/heating-museum/monitor-bi-loop-hot-water-radiators/
Thanks, @Steamhead! Your knowledge of these older systems continues to wow me.President
HeatingHelp.com0 -
Well, that's why we're here. BTW, I just found an old Monitor Bi-Loop catalog online, and it's on its way to Baltimore. I'll go through it when it arrives and will likely post more stuff here- watch this space.Erin Holohan Haskell said:Here it is: https://heatinghelp.com/heating-museum/monitor-bi-loop-hot-water-radiators/
Thanks, @Steamhead! Your knowledge of these older systems continues to wow me.All Steamed Up, Inc.
Consulting0 -
Fantastic!
President
HeatingHelp.com0 -
Wow this is neat. I suspect it would work well.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
