Fix leaky pipe on old Corto rad
northernsoul
Member Posts: 134
in Gas Heating
Hi there
Noticed a small drip at base of rad at fill pipe. It's slow,, but I want to fix it so I don't have to turn off the radiator
They are original Corto cast iron rads from the 30s I believe
Looking to see if I can fix myself or do I need to call someone in ?
Thanks
Thanks
Looks like the nipple between the valve and the radiator needs to be replaced. You may be able to do it yourself but you probably ought to wait till the weather breaks. You may need a right/left threaded nipple??0
Thank you - will the system refill water automatically or do I need to do it?
Should I shut this rad off for now is the slow drip not an emergency?
We only have another month or two left of heating so guess the fix can wait till spring0 -
Can't answer that question. Does the system have a water feeder on it that is left open? One of the HW Pro's on here will have to address if shutting the radiator valve off will do any good or how that might affect heating/water flow.0
Shutting the valve won't do any good- the water will enter thru the return connection.
Yes, that is a right/left nipple. Probably best to replace the entire valve with one that has a union nut connection.All Steamed Up, Inc.
Consulting1 -
Thank you - do you think it's fine to leave as is (with a pan under it) until it warms up outsideand we can turn off the system ?
It's only dripping maybe a half an once every few hours0 -
The return nipple might be left/right also?
But if you replace the valve you would have a union and be able to leave the return pipe as is.
You might have to get an extension for the valve spud though.0 -
Thanks- I'm going to assume putting a new valve and connectors isn't cheap0 -
@northernsoul , depending on what you call "isn't cheap" it shouldn't break the bank. In any case, it needs to be done before next heating season.0
Thanks I was more trying to figure out how big a job it would be to replace the valve - like does the rad have to be moved to switch it, or the flooring cut etc.0 -
The floor should be fine. The unions will make the lines in and out a little longerYou can have it good, fast or cheap. Pick two0
If it were me, I don't think I would change the valve. It looks to me like you have enough room between the valve and the radiator to cut that nipple, try to turn each half out (after getting all the paint off of the ends that screw into the radiator and valve). I would then use a short or close nipple on each end with a union in the middle and connect it back together. You can probably do that yourself when the weather breaks and you don't have to rush to get the heat back on. You will have to drain the water out of the system first and the system will have to be bleed after you refill it, but that will be the case if you do it or have a Pro come in to do it. If you are leary about bleeding the air out, you can always get a Pro in to do it for you or you can have them to the whole job but I don't see a need to have to move the radiator or cut any flooring.northernsoul said:> @Fred said:
Fred's idea is easiest if there is enough room for two close nipples an a union.
But even if there is, I expect when you try to turn the nipple out it will egg. It will likely need to be cut out. Which means the radiator will have to be disconnected completely to do so.
Looks like you might need someone trained in the art...New England SteamWorks
newenglandsteamworks.com0 -
my advice would be to get a pro if you uncomfortable with this, this is one of those jobs that can turn into a nightmare if you don't know the tricks and the things to avoid. You don't want to shear that nipple off in the rad and have a really hard time taking it out. Try the find a contractor link on this site.0
Thanks -
Would it help if I at least first tried to tighten the nipple with a wrench? Or is likely going to do nothing and might cause more issues ?0 -
Located in Ontario0
That leak is likely a thin spot on the threaded section, of that nipple, that has rusted through. Wait until you can spend some time replacing it or have someone replace it for you.0
- 87.2K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
