Mixing valve
cnmdesign
Member Posts: 103
Using a Taco 5000-3-G to mix water out of my DHW storage tank. Will the check valves in the mixer determine placement of the pressure tank or can I place it in the cold inlet just inside the mechanical room? Thanks
Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com
Steve thanks for your reply. At this time incoming cold water has no check valves. Only check valves in the system will be located inside the mixing valve on both the hot and cold side.Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
www.afinalsalute.com0 -
Will check valves in mixer increase expantion pressure in DHW tank?
Thanks
Thanks, I all ready put in an inline water pressure gauge so I know exactly what the pressure is all the time. How much fluctuation can the system make up for before I have to change the tank pressure? It's on city water.Combat Veteran owned, Final Salute LLC on FaceBook & Twitter.
- 123 Chimneys & Flues
