Quirky primary loops
hot_rod
hot_rod Member Posts: 26,579
Here are a couple loops I have built over the years.
See if you can figure out the buffered Munchkin wall loop, it has a key component that makes it work.
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,875
    Let me guess. Invisible Venturi fitting to induce flow? :smiley:
    I like the circle loop the best.
    ME
    Dan FoleySTEVEusaPACanucker
  • STEVEusaPA
    ME
    x2
  • kcopp
    kcopp Member Posts: 4,628
    Classic Hot Rod... :)
    Canucker
  • lchmb
    lchmb Member Posts: 2,997
    incredible..
  • the_donut
    the_donut Member Posts: 374
    Are you sure the munchkin rack on wall isn’t your new chair warmer?
    A disc soldered between the two tees forces flow down thru the buffer tank. Basically a 50 gallon Munchkin, for a multi, micro zoned home.
    kcoppSolid_Fuel_Man
    I did a bunch of buffer tank systems back 12- 15 years ago when I was installing full time. I liked this sealed combustion Crown boiler, easy to vent and bring combustion air right into the cabinet.
    The Robert Bean ZCPs.
  • Mark Eatherton
    I found that a nickel ($0.05) fits perfectly in the bottom of a 3/4" copper fitting. Drill whatever size hole you need, and you've got it made. :smile:
    ME
