Boiler Jacket Insulation
gmcinnes
Member Posts: 130
My large, hot-water boiler jacket insulation has disintegrated. What's a good choice to replace it? It was previously 1" fibreglass, by the looks of things, but it may be worth it to replace it with something like this: http://www.buyinsulationproductstore.com/roxul-enerwrap-80/ to decrease standby losses.
What do you think?
What do you think?
Yes, mineral wool is good quality insulation. You could use that or 2" fiberglass duct wrap if it will fix under the boiler jacket.
I would remove the jacket panels and old insulation. Clean loose debris from the jacket panels. Put some spray glue on the panels and stick the insulation on.0 -
yes0
