UEi Test Instruments C85 EOS - Reviews?
GregBl
Member Posts: 16
in Oil Heating
Hello,
Considering buying a UEi Test Instruments C85 EOS combustion analyzer for #2 heating oil. Please let me know if you have any experience with this analyzer. Thank you!
Not your best choice. No NOX filter. I have the C155, now used as back up, and currently use the Bacharach Insight Plus.
Steve,
Thanks for the input.0 -
You can add a NOX filter for $40, or less-0
ced48 - thanks for the feedback. I ended up going with Fieldpiece equipment (SOX3, SCM4 and SDMN5). However, they don't recommend using the CO for direct flue measurements. From what I've read, the missing NOx filter is probably the reason. I'm going to call them to discuss. BTW - where can I get a NOx filter for $40 or less (I've only found them for $50 and up)?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 986 Plumbing
- 389 Solar
