Boiler & Hot water heater venting
Jon2018
Jon2018 Member Posts: 15
edited January 2018 in THE MAIN WALL
Deleted
  • unclejohn
    unclejohn Member Posts: 1,833
    Your vent pipe looks OK. Most codes require a 4" on the water heater which, by the way appears to have about a 1/2 hour of life left.
  • Jon2018
    edited January 2018
    deleted
  • j a_2
    j a_2 Member Posts: 1,804
    Jon2018 said:
    Hmmm, my understanding is that the hot water vent pipe should be above the boiler pipe. No?
    Yes always smaller over the larger..
  • Jon2018
    edited January 2018
    deleted
  • j a_2
    I am sure your mechanically inclined,however you may, at minimum want to get a consult from a local professional, mistakes can be deadly..
