Honeywell OA reset controller
Chuck_17
Member Posts: 148
Quick couple questions (so I don't have to spend half the day figuring it out):
Honeywell reset stage control.
The setpoint is the hot water set point at the coldest OA temp?
What exactly is the control band in this case?
How does the control know the high end and low end outside air temps?
W7100J
I found a data sheet online.0
- 117 Geothermal
