In Wall Convector Vent Removal
kd47828
Member Posts: 3
My home was built in 1938 and has a number of convector radiators built in to the wall with an opening at the floor for intake air and a vent panel just under the window sill for the heated air to escape. A couple of these units have vents that need replacement but I cannot get enough access to get a wrench on them. The vents have an 8 point pattern for a socket but I cannot find a deep 8 point socket that will work. Does anyone have any history in attempting to remove vents from in wall convectors?
Can you post a photo?Hydronics inspired homeowner with self-designed high efficiency low temperature baseboard system and professionally installed mod-con boiler with indirect DHW. My system design thread: http://forum.heatinghelp.com/discussion/154385
System Photo: https://us.v-cdn.net/5021738/uploads/FileUpload/79/451e1f19a1e5b345e0951fbe1ff6ca.jpg0 -
Attached is a pic. You can see the sheetmetal lining on either side of the radiator
The front panel should be removable unless it's plastered over. You may have to cut a hole.0
The convector is behind a tiled wall. The access panel is well above where the vent is.0
Try snap-on tools. A big socket looks like your best option. Unless your a tile man.0
- 125 Chimneys & Flues
- 121 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
