Fire Tube HX
Solid_Fuel_Man
Solid_Fuel_Man Member Posts: 2,644
edited January 2018 in THE MAIN WALL
This is my first firetube mod/con. Took some pictures just for fun. Mod/cons are few and far between in my line of large commercial work. This is my own boiler which will replace a toyotomi 180 boiler as my back-up.
This is a Polish manufacturer Tuchom which I suspect many brands use. Weil Mclain ECO70. Interesting to note that 100% of the materials that come in contact with flue gasses are made of polypropylene.
  • Henry
    Henry Member Posts: 998
    It is actually an AIC heat exchanger made in Tuchom which is near Gdansk. Several US manufacturers used this model and others from AIC.
    Solid_Fuel_Man
  • flat_twin
    flat_twin Member Posts: 354
    Interesting view from the bottom of the HX. You must have removed the bottom of the cabinet as well as the condensate base/drain.
    Curious to see this job as it progresses and how it's piped as a back up system
  • Solid_Fuel_Man
    Yes removed the bottom of the cabinet, and the polypropylene condensate drain base.
    @Henry Yes you are correct, AIC is the manufacturer, I didn't look very carefully!
