NTI TX151 combi boiler
lchmb
Member Posts: 2,997
anyone familiar with the NTI control and programming?
yup a bit, but NTI support is unbelievable. Whatcha got?
Tom
Montpelier Vt0 -
looking to change the boiler parameter 2-03 to 3. I have a high temp application and cant use the outdoor reset to maintain temp. I went into the setup but it will not allow me to change the setting..0
Isn't that the same as option 0 just works off whatever you set the water temp to? Will it go to option 0 or can you not get into the parameters section? Not being sarcastic just want to make sure of what you are trying to do.Tom
Montpelier Vt0 -
with option 2-03 set to 1 which is from factory it will use the outdoor sensor and run a heat curve. I want it just to maintain temp and or set the heat curve to max temp at 32 degrees
Yeah, agreed, can you set it to 0 not 1
Tom
Montpelier Vt0 -
no..the instructions show to go to the parameter and hold the enter button til it flashes..it doesnt flash.. I'm just surprised it wouldnt allow you to change that setting...0
Weird, you are entering installer by holding menu and ok together for a few seconds?Tom
Montpelier Vt0 -
yes.. my thought is they dont want it changed...but that makes no sense..0
They don't celebrate Christmas up there I would call Monday morning and ask. They have really good Tech support.Tom
Montpelier Vt0 -
Or maybe they do and its thanksgiving thats different. Either way give them a shout
Tom
Montpelier Vt0
