NTI TX151 combi boiler
lchmb
lchmb Member Posts: 2,997
anyone familiar with the NTI control and programming?
  • Tom_133
    Tom_133 Member Posts: 930
    yup a bit, but NTI support is unbelievable. Whatcha got?
    Tom
    Montpelier Vt
  • lchmb
    looking to change the boiler parameter 2-03 to 3. I have a high temp application and cant use the outdoor reset to maintain temp. I went into the setup but it will not allow me to change the setting..
  • Tom_133
    Isn't that the same as option 0 just works off whatever you set the water temp to? Will it go to option 0 or can you not get into the parameters section? Not being sarcastic just want to make sure of what you are trying to do.
    Tom
    Montpelier Vt
  • lchmb
    with option 2-03 set to 1 which is from factory it will use the outdoor sensor and run a heat curve. I want it just to maintain temp and or set the heat curve to max temp at 32 degrees
  • Tom_133
    Yeah, agreed, can you set it to 0 not 1
    Tom
    Montpelier Vt
  • lchmb
    no..the instructions show to go to the parameter and hold the enter button til it flashes..it doesnt flash.. I'm just surprised it wouldnt allow you to change that setting...
  • Tom_133
    Weird, you are entering installer by holding menu and ok together for a few seconds?
    Tom
    Montpelier Vt
  • lchmb
    yes.. my thought is they dont want it changed...but that makes no sense..
  • Tom_133
    They don't celebrate Christmas up there I would call Monday morning and ask. They have really good Tech support.
    Tom
    Montpelier Vt
  • Tom_133
    Or maybe they do and its thanksgiving thats different. Either way give them a shout
    Tom
    Montpelier Vt
  • kcopp
    kcopp Member Posts: 4,576
    Yes it TG that is different... they celebrate their TG on our Columbus Day.
