Buderus Logamatic Control HS2109
Buderus_Owner
Member Posts: 2
It appears that the fuse and fuse holder on the front of the control is broken. The boiler is dead. Buderus says I need a third party fuse and fuse holder (10 amp) since the part is obsolete. Any hints on accomplishing this without buying a whole new control? If there's a way to post a photo, I'll be happy to do so (I'm new here!)
Thank you for any help. I'm in Southern California and hydronic specialists are a rare breed.
1
The 2109 is no longer available. You could upgrade to the 2107 with outdoor reset or install a standard Honeywell, Hydrostat or Beckett aquastat. You'll likely have to replace the well also with a standard aquastat.0
